Hello All,
I'm considering going back to the original plates in my distributor. It seems to me to be easier and more accurate to set the points with the original set up.
I don't recall why I converted to the modern plates as I didn't have problems with the original. About the only thing I can think of is that I may have been concerned that the block on the movable point arm would wear down more than the modern. Even so, I doubt it could wear so quickly as to be an issue.
This caused me to wonder which set up is in more prevalent use today, and why.
Thank you.
Thank you.
