FWIW: Original 80+ Year Old Radiator Care 101; written years ago:
So many "original", functional well made Ford parts "incorrectly" already often made it to the junk pile; however, if you like the looks of your original radiator, and you are willing to experiment just a little, you may .... or may not .... want to try this one "vintage" recommended method to successfully clean "vintage" radiators overnight:
A. Many original radiators are still in use & still work just great. Some were professionally cleaned by rodding out mineral deposits, some were not; and some were cleaned with detergents and other methods, and also some were cleaned as described herein by a Model T and Model A most respected technical expert, Mr. Victor Page, who wrote articles years ago.
B. Radiator geographical location is important because of different types of water and anti-freeze used and added to Model A radiators; e.g., well water with lots of mineral deposits, water from water filtering plants, rain water that never touched earth, stream water, lake water, river water; plus numerous types of different antifreeze materials etc., etc.
C. In his book, (not read often today), Victor Page explains "why" radiators cease to cool engines:
1. Even if we exclude harmful cast iron engine rust deposits and/or grease from over-greased water pumps clogging tubes, the water in different localities contain foreign matter, either in suspension or solution, which will form a powdery deposits in radiator tubes; and it does not take too much scale to reduce the ratio of heat conduction between the heated water inside of the tube and the cooling air currents which are circulated about their exterior.
2. Some anti-freezes used, salt, such as calcium chloride, as a base which after time may deposit solid matter in the form of crystals; whereas cheaper glycerin based anti-freeze solution had a chemical reaction that deteriorated engine cast iron water jackets and contributed to rust deposits in radiator tubes.
3. Radiator tube "incrustation" is caused by carbonate of lime, which in some waters becomes a bicarbonate; thus when engine coolant is heated, the carbonic acid is driven off and the carbonate is precipitated in the from of a muddy deposit, which hardens in the presence of heat into a non-conducting scale where heat is greatest and which remains in the form of a powdery deposit in radiator tubes.
4. Sometimes other deposits are in the form of sulfate of lime.
5. A solution of "Lye", (Caustic Soda) "will" clean out water spaces in radiators, and will "cut" both rust and scale, and will "dissolve" rust, or loosen them sufficiently so the deposits may be thoroughly flushed out with water or steam under "pressure."
6. Cleaning Method:
a. First fill entire cooling system with water; then drain cooling system to "measure" contents of cooling system liquid.
b. Dissolve solid lye in water with a ratio of: 2-1/2 pounds of solid dry lye to one (1) gallon of water ..... thus mixing enough to fill the entire cooling system. Stir constantly because heat is generated when mixed. When the liquid has cooled, add to radiator opening.
c. Allow mix to stay in radiator overnight, drain in the morning, and flush with clean water under pressure.
d. WARNING: Read all lye caution labels and cautions on line for handling lye, such as wear protective glasses; do not allow lye- mix to get on one's skin or body parts or on painted metal; etc. etc.
7. Finally he states that the reason water contains so many impurities is because it is one of the best know solvents; pure water is never found in nature and can only be obtained by distillation. He also mentions that the purest "natural" water is rain -- (this was prior to our present air pollution), which has "not" touched earth.
8. Many suggested radiator cleaning methods can be found on line -- many work successfully -- some do not.
9. Just one (1) inexpensive "vintage" something anyone may want to think about in the future prior to discarding an old original Model A radiator.
10. Also, once cleaned, it can never hurt to provide "distilled" water in Model A radiators.
