mrtexas
I have what I believe are two sets of original rumble hinges although if I were sure they were original I wouldn't be posting here. I base this on the Ford part number cast into the hinges. One hinge of each pair has a Ford number A 52... on it that is hard to read. One pair fits and the other doesn't.
1st pair fits that came with the 29 roadster:
A second pair of original hinges has a Ford number on them as well but the hinges don't fit my lid and that I bought from a reliable source that advertised them as original.
The 29 roadster came with a set of homemade brackets to attach the hinges. The second pair came with the correct bracket and bolts. On the pair that fits and I am using, the pivot bolt holes are different sizes for each side. In fact I took one of the bolts to a machine shop this week to enlarge the head of the bolt. Out of the 4 hinges, 3 have the small pivot bolt head and one has a larger bolt head.
Can someone explain all this?
