Have you any proof of this?Remember that Henry often used 'scraps' left over from shipping crates to build his floor boards, so the boards often times varied in both width and in wood type, as well as finish.
Examination of my March 29 truck front (it's missing the lower board) shows that uneven scraps were used. The lines across the board are not parallel and at the top where the pedal slots are done its apparent the wood on either side of the slot is not from the same piece.
There may have been a butt-joint across the spot where the slot was later made. Someone with some smarts obviously anticipated the positioning of the afterwards executed slot.
I took that at the time as example that Ford was using the cut up boxes of sub-contractor shipments. (which would support a hypothesis that Ford specified not only the parts but also the box dimensions they were to be shipped in) But while a logical conclusion others on this board have pointed out the evidence is not necessarily proof without collaborating contractural or other documentation.
Plus, even in 1928-29, use of hardwood for shipping crates would have been exceptional overkill.
They may have been using Ford's own scraps - a labor intensive effort for sure - and you can see they certainly would get away from this by using virgin plywood for the later builds.
Joe K
If you look real close to the cut out pegs for the brake and clutch you will find a wood dowel pin stuck in each of the two end ones down into the next main board to give them more strength.. Most found today are broken off..
Speaking of cuts, have you noticed the round sawblade cuts on the bottom side, that extend beyond the battery hole?
Good point Dave.
Actually I meant the ones at the battery access hole, which wouldn't be there if a saber saw was used to cut the oval hole. I'll be putting them in my repro boards.
I haven't looked at my original boards for years, but would think the end radius was cut with a hole saw.
My floorboards are painted with a black thick tarlike paint. Not regular paint. As far as I know it is all original.
