Original Model A Parts $20 under
FlatAddict
Beach
ND
Price
in add
All items + shipping. PM for quotes.
Stuff added down below so scroll through.
1. Backing plate bolts long and short $5.00 for all (sold)
2. Backing Plates $5.00
3. Coil Clamp $2.00 Voltage Regulator $2.00
4. Crank Nut $5.00
5. Dipsticks 2 outside $5.00 each 2 inside $2.00 each (Oval Dipstick SOLD)
6. Column Drop Clamp $10.00(SOLD) Hood Rod Retainer $5.00(sold)
7. Aluminum Finned Coil $10.00
8. Gas Tank Clips 2 sets of six $5.00 each set (sold)
9. Dash Panel #1 $20.00 #2-#5 $5.00 each
10. 2 tooth steering sectors $5.00 each
11. Sediment bowls $3.00 each $1.00 for the cap (1 on left sold)
12. Model A Spark Plugs and Parts $10.00 for all (SOLD)
1. Speedometer Bezel, small crack $5.00
2. U-joint Clamps and a bearing retainer $10.00 Each
3. Water outlats/necks $5.00 each
4. Model A water pump bearing $3.00
5. Brake Shaft $5.00
6. Clutch Shaft Clamps $5.00 for the pair
7. Distributor $5.00
8. Flywheel Cover $3.00
9. 30-31 Lower Grill Shell removable insert $10.00
10. Various guage parts $5.00
11. Water pump impellar and shaft $10.00
I'll take the spark plugs and the bottom dipstick.... the long oval shaped one. Shoot me a pm with shipping cost.-Weeks
Don't mean to early bump just need to add stuff.
1. Oil Filler Tube $3.00
2. Shift Tower for a 30' AA 4spd $20.00
3. Brake Shoe Cores $10.00 for all. (SOLD)
4. Sport Coupe Top Iron $20.00
5. Throwout Bearings and springs $5.00 each
6. Toe board column plates (I think???) $10.00 each
Do you have any tire gauges or any other tool pm me and let me know what you have left thanks how coils do you have do you have any original 31s left
