1955cj5
I have an old Standard ignition coil that works fine.
What I don't have is the Ford "can" and mounting bracket that is original.
So, if I buy a used original style can with a coil( similar to the picture), and the coil itself does not work, will I be able to remove the old non-working coil from the "can" and replace it with my Standard brand coil, or some other if the Standard does not fit?
Seems to me that I read somewhere that you could do this.....
Thanks,
Randy
Thanks,
Randy
