Barry in St.Paul
hi,
I have a Tom Wesenberg (oh how I miss my friend!) EVR on my generator, and have put up with the "all or nothing" charging while using it with a diode-type cutout. Finally learned that his EVR needs the original style cutout to work properly, OR a wire needs to be cut on the EVR. I'm trying the first approach, have my original cutout, checked and adjusted the point gap, air gap, and confirmed it had continuity with points closed. Installed it on my generator, started her up, and.... no charge. Checked generator with a wire bypassing the cutout and full <20 amps, so generator is OK. Cutout points are closed as I rev the engine higher, as they should. But no output from the generator. I don't understand how this is possible, since there is continuity between armature post and battery/wiring post on cutout when I close the points. Any ideas? I'm bamboozled. THanks!
Barry in Minnesota
PS: secondary question: initial trials, the points STAYED closed after I turned off the car. I manually pulled them open and then they stayed open until I started car again. And then stayed closed again. Later, they opened up as I was about to call it quits. Was almost like the pole magnet was still energized, even though car was not running. Can't figure that out either. Fresh shiny points, so not sticking....
PSPS: have not posted for a LONG time, the 'A is up at dad's farm while I work on my Studebaker; the little girl in my avatar graduated from high school this weekend
How time flies!!
Barry in Minnesota
