Original 3X Spark Plugs
Tom Wesenberg
....................... Here's another one with the higher "3X" said:
http://www.ebay.com/itm/Model-A-Ford-Original-Champion-3X-Spark-Plug-Thick-Base-1928-1929-7009-/322378053373?hash=item4b0f3ab6fd:g:laAAAOSwal5YGiD-&vxp=mtr[/URL]
That is not an original Champion 3X base.
On the set of four, it looks like the inside copper washer or bushing is not installed.. If is was it would raise it up..
I understood that on the original 3X plug the 3 had a flat top instead of a round top on the 3.
Original plugs
How do the spark plugs pictured (as 'original') differ from the reproduction Champion XXX "Exact Duplicate" spark plugs that were made 30 to 40 years ago?
It might help some of those unfamiliar with the difference, to learn. I myself could use a 'refresher' course.
just the opposite
The original 3X plug, the 3 had a ROUND top.
The reproduction 3X plug, the 3 had a FLAT top.
I've been searching the posts to get opinions on a good plug for 5.5 head and 12 volt,FS ignition. Some say use the W18 Y which is now a Champion # 518 plug according to their website. The 3x is now available as a #429, see attached. Does it look close to the originals?
It does look "CLOSE" to the original, must have a copper gasket, and most won't notice the flat "3"....
Doug this flyer cover the shape of the top of the 3, the hex height and the knurling.
Flyer from a Champion 3X Spark Plug seminar put on by John Hash and Rich Street, MAFCA 2010 National Convention Vancouver BC.
Thank you ! 30ccpickup, for the answer to my question, and a wonderful education regarding how to tell the difference between an original and a reproduction Champion 3 X spark plug. The http://modelabasics.com/3xplug.htm website was a great explaination and goes a long way to re-inforce the old adage: "One picture is worth a thousand words".
Tom Wesenberg, post #18: "X2 those are fantastic"
Tom, don't you mean 3X !
