Dave36ford
- City
- Succaunna
- State
- NJ
- Price
- 3900
Just picked this up from where it sat the past 30 years, was going to build it but may have a change of plans. Look at pictures closely, there is some rot on the frame but it’s fixable.
Complete rolling chassis with 4cyl trans, all pedals, steering column, firewall is very nice with only minor rot on the drivers side top flange, heavy axle, 17” wires (I have the 4th on the side), Unsplit bones are nice. Frame is rotted on both the driver and passenger side lower from the rear tire to the K member. Minor rot on the drivers side top near the door opening. Putting on sides worse in the drivers then passengers but all fixable. K member is solid with a minor patch needed on the passenger lower.
32 pickup body panels are for parts or could be saved. Passenger door will need work but you know they aren’t the easiest to find, cowl has a crack on the passenger side and sides are loose, cowl vent is there but the flange is shot, cowl assembly is complete it seems. Back panel is relatively solid but soft around window. Roof is pretty solid overall but edges and drivers corner of visor need work.
passenger side rolls, drivers is locked up. Steering wheel turns and box is free. Will move easily with dollies under locked wheels.
located in northern NJ. 3900 obo. Send me a PM. I can take more pics if you’d like but easiest to take a look in person. Thanks
