Original 1955 Ford F100 panel
fordtrk56
San Diego
Ca
Price
3500
1955 panel..6cyl-disassembled for rebuild,4spd granny trans,new front drums,front brake shoes,bearings,seals and king pins,front U bolts and driver side front spring.Has ALL Good Glass with no cracks.Fresh Air heater with controls and defrost ducts and deflector,steering column and box,glove box door with Vin plate attached that matches frame numbers.Waiting for the title to arrive.Original gauge cluster and a decent used wiring harness.Stock bucket seat.Both hood hinges.Very straight front bumper and stock rear bumper.All inside and outside handles plus window crank handles.Both rear doors have the upper door stops,all mechanisms inside with both handles and no broken door hinges.All interior lower metal body panels.Nice 55 grille with head light trim rings and 6cyl star.Gas pedal and pedal assembly.This truck is equipped with 8 lug suspension..I have lots more pictures to share as well.Delivery available to the local San Diego and Los Angeles areas.
