Original 1932 pedal assembly
64DRK
Hello all. I am desperately looking for a set of original 1932 pedals. If not the pedals at least the mounting bracket. I am mechanically restoring my father-in-law's 32 Sport Coupe and found that the previous "Mechanic/Restoration Shop" cut the mounting bracket and used a hydraulic master cylinder I am not familiar with. I'm not sure I will be able to rebuild this setup and want to make it easy for my kids should they need to rebuild it in the future. The K member is still intact and I would like to keep it that way.
ANY help is GREATLY appreciated!!!
DK
Cuz you are a new member here. To make it harder for internet scammers to respond to ads, this site won't let you respond until you have made 10 posts. Just make a few more dummy posts, then you should be able to respond.
If you end up keeping hydraulics (depending on how/where the car is going to be used it might be a good idea) here is how I did it using original pedals. Too bad your previous owners didn't't do it this way.
PS, You should put your general location in your profile.
Charlie Stephens
Charlie Stephens
531105
531106
IF you want to keep the existing hydraulic setup ("if it aint broke, dont fix it") you may be able to source the cylinders from a mainstream parts store IF there are casting numbers on said cylinders.
