Isn't caster determined by the front crossmember? I don't see how cutting the wishbones would change caster...unless you're putting the front spring in a bind.
Getting my head around this.... must go and measure them when I get home.Heavy or hard steering with those small tires could also be from your steering ratio. The effective length of the steering arm on the spindle as a ratio of the length of the pitman arm. For example; a ratio is from about 0.85:1 to 0.95:1 yields reasonable steering force, and speed. Less than 0.85:1 can result slow steering and reduced road feel. Above 0.95:1 too much effort.
