First off I'm retired from the automotive parts sector and one of my benefits is I can purchase most parts at cost.
Originally I had one 6 volt Optima installed. I was having some trouble with the headlights being dim, slow cranking etc so when I had the car disassembled for some major changes to the driveline, I decided to convert to 12 volts. Instead of changing out the battery for a 12 volt, I got another 6 volt and was going to hook them up in series. As a test, I tried it out in parallel and it worked really well, so I kept it 6 volt. I now have a Denso (Toyota) alternator converted to 6v pos ground hidden in the generator case, LED headlights, turn signals etc. I also replaced all the original wiring and paid extra attention to making sure everything had a good ground. I think the grounds were the source of most of the original poor performance. The headlights are incredible, super bright white light like a HID system and the amp gauge barely moves when I turn them on. Very happy with it.
