The Optima is just like any lead acid battery, except the plates are coiled rather than stacked, and it is sealed (SLA = Sealed Lead Acid). The nominal voltage at rest is 6.3V, 2.1V per cell. Optimum float voltage is 7.2V while charging.
How about using some spacers on the stud to get up to where the threads are.
Use some larger nuts as spacers or even a bunch of flat washers if you do not want to make sone spacers.
I do not like to put something under the battery to raise it up. It may loosen up and fall out while going down he road.
Just my opinion.
Chris W.
Just my opinion.
Chris W.
Bratton's sells the correctly shaped bracket to use an Optima in the original Model A battery holder; the bracket you picture looks incorrect for an Optima installation.
No, the bracket in my photo fits the Optima 6v fine and is sold by the other suppliers. With the Bratton's bracket is there still an issue with height when using original studs?
I bought the one in the photo and returned it right away. Quality was poor, and it could have shorted on the posts.
Now I have the oval shaped one from Brattons, and it looks good and fits. No spacer required.
there's your answer.
I agree with you about not wanting to put anything under the battery.
