will a regular 6v 6amp Sears charger work OK to charge a 6v Optima once a month or so, just to keep it up? The charger backs off to 2amps as the battery charges.
I have a portable (small) Sears Platinum charger and love it. It charges Standard AGM GEL and Sears PLATINUM batteries. It pretty much does it all for you except select the battery type. It goes through an analyze process etc. Once charged it automatically goes to maintenance. Make sure the charger has the AGM option which is what your Optima is. Mine even tells me if my battery is bad.
Yes, it will but it will not work if the Optima is dead. You must then either use an Optima / AGM Approved charger or put it in parallel with a 6 volt battery to charge the Optima.
I have several Optima batteries and they are all AGM (Absorbed Glass Mat). The charger I mentioned above will work for most automotive batteries and for $99 it one of the best "garage toys" I've bought.
I saw somewhere that you needed a special charger for "SOME" Optima battery's. I wondered about that because generator, alternator or AGM charger, how would the battery know the difference? 6 volts/5-8 amps DC is the same whether coming from charger or charging system, isn't it? Or am I missing something?
the Optima is not dead, just resting until next year driving season. It starts all the time, I just wanna make sure it is fully charged.
Again, is my 70's Sears 6v charger, tapering down to 2amps OK to use for a 6v Optima?
