4t,
You cannot beat Bubba that is for sure. You might think about degreeing
your crank pulley. Measure the circumference of the pulley, divide that number by sixteen. That
number equals 22.5 degrees in inches. Because I can never remember which way to go I always mark that number/length in both directions from TDC. 22.5 degrees is
generically about the max advance for a street Flathead. So with the vac can disconnected and the vac line plugged fire the engine up and set initial at 4 degrees.
Now this is when the sbc/8ba converted dist really shines and I think your MSD is set
up with the wts and springs under the rotor too. With a hand held cheap tach rev
the motor to 2200/2400 and you want to see the timing cover pointer at the 22.5 degree mark. There are limit bushings with various offsets and diameters that will
get you to that 22.5 degrees max, or real close. The next step is a learning process,
you want to get to 22.5 smoothly but quickly, this where your box of springs and fly
weights come in. It usually takes a few tries and some road testing. You'll be in the
ball park.
Charlie ny
