13
I wanted to run this by everyone. I will be attempting to to see if this motor will run. 12v neg. ground, hot wire to resistor then to (-) coil, (+) coil to ignition switch, switch to distributor. I won't be able to try it until after all the time up parts arrive, does this seem correct? This is onlyto see of it'll fire (hotwired)Thank you!
