BillyBobsSpeedShop
I am working on a project and currently in the process of assembling my rear end. I currently have a very good condition stamped steel rear brake drum and hub assembled together that is measuring .141 thickness. I also was able to find another complete drake drum and hub from a local Model A'er that is from a late 1931 and is the cast drum in really good condition as well. So my question is what issues should i be concerned with running a stamped steel drum and a cast drum on the rear? Or should i be good?
I started this venture with purchasing a set of cast drums and went down the path with having a local machine shop install them on my hubs. Unfortunately that process did not go so well and both drums cracked during the install process and are not good.
Thanks
Thanks
