Charles Reese
1. Is the lower rubber weather-strip ('28) slightly beveled at each end to provide an overlap on the stanchion rubber strips … or are the ends simply a straight cut as supplied from the vendor? If beveled, any specific angle? Pix would be helpful.
2. Should the stanchion rubber weather-strip ('28) be only a snug fit or should I add a dab of sealer/adhesive to secure the rubber to the stanchions? As in question #1, any beveling at either end?
Thanks, as always!!!
