Oops
fiddlybits
Found a small flaw..
Maybe a little JB Weld? :D
Fill the broken area with soft bread. Slather on the jb weld to cover the bread and let set. Once the water enters the head the it will dissolve the bread and the open the passage. :eek:
Time for a modest high compression head?
One of the basketcases that came to me had been through a freeze-thaw cycle. Maybe more than one by the look of the cast iron bulge that had lifted from the center top of the cylinder head.
Nothing to lose, I brought it in to the power plant and tried to play a game of tack brazing it down after pushing the lifted portion back into place with a clamp.
It was for naught. Another one of those "chasing the crack around" with a welding torch.
I finally realized that I was wasting the company's gas, and my time, and that $10 at Amherst, NH would buy me a perfectly fine used head.
It went in the scrap bin.
Yunno - someone fished it out of scrap and tried to pick up on it welding where I had left off?
It must be the challenge. Like a thrown gauntlet or something.
Joe K
Wonder if anyone ever tried machining a block/head, to accept freeze plugs?
Even a simple open hole, with a CORK, might work?? OR, those old thermos stoppers, with a locking lever.
Bill W.
I have one that did not make it through a freeze.
Just like ice cubes in an ice tray, the ice expanded upwards & pushed the top center of the head upwards.
At the longitudinal center of head, one side is about 3/16" high.
Rather than discard same, it makes a good device to use to install & extract engines.
I think the name for freeze plugs is a misnomer, they are to fill holes left from the casting process that were use to empty sand cores. Besides, me being in a freezing climate, I've seen cracked blocks where the freeze plugs are still good.
Yep, they should be called core plugs or welch plugs, as they have nothing to do with preventing freeze cracks.
The head pictures also has a lot of flaking rust that works well for plugging up radiators.
Heads like this are good for show and tell cut-a ways.
This was one of 4 engines I just acquired and have been tearing down. Three loose and one in a rolling chassis.
The first two came apart easily and magna-fluxed out perfect.
This one was the nastiest looking of them so I saved it for "last". (the one in the frame is the "last last" one to go through since I have it running. I assume everyone knows the difference between last and last last. ... it's like being hungry but not being hungry hungry. :D )
If you look at the photo, the left side of the hole had an old crack that runs vertical. I noticed the head had about a dozen of those cracks all the way around the head. The broken piece popped out with the first tap on the knife to unseat the head.
To finally get this head off I had to drive a pipe up through cylinders 1 & 4 with a 10lb hammer. It had a death grip on the studs.
The rust flakes are a good reminder to BACKFLUSH your radiator, once or twice a year! They are ALWAYS there & WILL inevitably end up stuck in the top of the radiator tubes!
Bill W.
Somehow I get the feeling that the JB Weld is just not going to cut it this time......
Major corrosion.... and a lot of stress fractures throughout.
Surprisingly.... the block magna-fluxed just fine.
