christian
Hello, Im trying to get my 31 running smoothly after being dormant since 1953. I have changed out many parts including a new distributor, a professionally rebuilt carb, plugs, battery etc. The car seems to run well and pulls great through the gears however when it idles it lopes badly unless i have the spark rod all the way up. I have the timing set to where it sparks a few notches down while at TDC. As far as the idle mixture screw, it idles best at 3/4 turn open from seat.
I hear that these are supposed to idle well a few notches down on the spark rod, and 1 and a half turns from seat on the mixture screw. Any idea whats going on?
thanks for any input.
