This my first go at a Model T engine overhaul. I'm not new at engine rebuilding - been doing it since the early '60s.
The engine I'm working on is supposedly a '25. It has the two rectangular valve chambers with the single long cover with the oval hole for linkage pass-through. The single long cover gasket has this hole also (obviously). However, this cover/gasket arrangement does not seal the chambers between #2 and #3 cylinders, and I can see a valve stem and spring through the oval hole. It does not look right to me: dust can enter and oil can escape.
What am I missing here? What can I do to correct this?
