One piece Front seal 8BA
I don't see the need for all this. the stock system works just fine. The 8BA has a sleeve. the early pulleys have the sleeve built on the crank pulley. All you need is the seal. I don't understand why we try to make thing difficult. Now with that said, some seals don't fit very well in the pan and cover. I try to stay away from them, However you can use RTV to take up the space.
Ron, This set up is required by Camden for the blower pulley set up I'm installing.
I would say you are going to need a notch. When you tighten up the pulley you will be jamming that into the key. Can you file a small notch into it? That would fix the problem.
This is what I'm thinking. The only problem I may have is the length of the sleeve to the pulley shaft. The pulley is just clearing the face of the timing cover. If I notch the sleeve, it will go in further on to the crank which means the pulley will do the same thing and possibly rub on the timing cover
If you need it spaced like it is you will need to make a spacer with a notch in it. A simple valve seat insert the right thickness could be used, then file a notch in it. Whatever you do you will need the pulley tight up again the crank gear.
In the passed I have trimmed the key to have the sleeve fit flush, but that will still gave you a spacing problem.
That's a great idea flatrod!
another excellent idea
I'm still waiting for the blower to come back from getting checked out so the spacing problem will have to wait until the blower is sitting in place.
Ardun, can you tell me if the sleeve has a groove cut into it to go on to the key or is it pushed up to the key?
Thanks, Joe
Here is a pic of the installed, smooth sleeve. IMG_0899.jpg Key goes on after sleeve is installed.
39,000 mi on my Ol'Ron flathead and front of engine is dry as a bone. Now the rear seal is another question. Slight but noticeable leak. Oh, I am useing thr spiral front pully.
Regards,Don
