Minn-Tex Lee
My previors question "why my new 12 volt coil " required a resistor I think is answered by the manufacturing company assuming it will also be negative ground. The primary and secondary coils are then joined at the negative terminal as opposed to the positive terminal. There does notappear to be any other difference in the coils.
The real head scratcher is the steering column angle.
This is supposed to be a 1931 Std Roadster. Some previous owner had moved the pittman down below the frame to make the column fit the steering bracket on the gas tank.
When I was restoring it I moved all parts to there correst place.
Now the column misses the support by 2 " and a new dash mounted bracket has the same problem. I can always shim it up but I fear the steering wheel will end up in my lap.
Also the gas tank looks sort of like a 1929 in that a round speedo type instrument panel wont quite fit the dash.
I have tried other steering gear box mounting brackets but they all look the same.
I would appreciate any thoughts on this problem.
Thanks
Lee
Thanks
Lee
