48Ratfink Senior Member May 26, 2011 #1 I have the peel and stick running board rubber,,,,any advice before I tackle this??
JunkOSC Senior Member May 26, 2011 #2 I couldn't get mine to stick very well. I had to removed all the peel and stick material from the rubber and use contact cement to get then to adhear.... making sure the boards are extremely clean.
Mitch//pa BANNED May 26, 2011 #3 same here i used weatherstrip adhesive. even if you do get it to stick in the heat it will lift in spots and youll have large bumps.
