With the wood gas "GenGas" that Joe is talking about, there was a lot of fiddling with the air/gas ratio as the wood in the generator burned. There was also a lot of wear in the engines because of the lack of adequate filtering of the abrasive particles. So, with modern filtering, and a computer controlled "carburetor" this may be a practical solution to high fuel prices, or the lack of fuel in the future. I would think that a pickup truck would be a better vehicle choice because the generator could be mounted in the bed of the truck. I have no idea what the ideal compression ratio would be.
The flame that you see when you burn wood in your fireplace is the wood gas burning. It is a combination of hydrogen, carbon, and carbon monoxide, plus some volatile organic hydrocarbons.
I am really impressed by the Lance Bulldog tractor. One cylinder, two-cycle, huge displacement, rpm you can count, and burning any kind of oil. A good source of used crankcase oil is the marinas and boatyards where people change the oil in their boats.
