Gunmetal blue2 Senior Member Mar 24, 2014 #1 My truck has the old terminal box body, will a repop cover work on the old body?
Tom Wesenberg Well-known member Mar 24, 2014 #2 It should, but don't be surprised if you need to move the holes a tad.
B bikejunk Senior Member Mar 24, 2014 #3 yes I have the same thing . with just a bit of futzing it fit really well right ot of the box.
jrelliott Well-known member Mar 24, 2014 #4 The repop cover I purchased from Little Dearborn in Minneapolis years ago worked. Plastic is not as good as the original hard rubber cover.
JackA Senior Member Mar 24, 2014 #5 I am fighting that right now after a repaint on the firewall. The holes don't really line up, but with a little frigging, I think it will go on. I am using a screw holding driver, as it is close down there.
rogerkb1936 Well-known member Mar 25, 2014 #7 if you rub the new cover well with steel wool it will look a lot like original finish
