old tachometer wiring help
LUCK R
Hello !
I have an old Sun Tach.
one of the first with no sending unit needed, I have four wires comming out of the back.
red
white
blue
black
Does anyone know the color code ?
Does the blue wire look like it could be a shade of green according to the wiring diagram Mike posted; Black would be ground, Red would be power, white would be the light and (Blue Green) would be to Coil + (if its a negative ground vehicle) it looks like the bulb is removable what wire goes to the base of the bulb? Regards, Brian
LUCK R:
Take this for what it is worth...I have a 6 volt POS ground system in my 53' Merc...I installed (temporally) a no name tach to check shift points and speed at different rpm's...it does have a switch for 4,6 & 8 cyl...voltage didn’t matter.
4 wire tach:
Black = hot (-) when swich is on
Red = ground (-)
Green = (+) side of coil
White = head light switch
2 wire tach:
No switch for no. of cyl's - 8 cyl tach from an old Jeep
one lead to (-) side of coil
other lead to (+) batt (w/ switch - I did hook it up hot to the battery the first time and found that when you turn off the ign switch the motor jsut kept running)
