BUBBAS IGNITION
This very well could be the oldest Mallory i have ever done. Customer sent this one in for a restore and set up. Tag says Mallory Governor, model 11A. I have a few old cores here but none like this one.
Tear down shows sectioned leaf springs with one weight above and one weight below. Pretty nasty insides.
The unit is very adjustable with many settings on the adjustment ring.( we use the 30 degree) it also has the mechanical adjustment as well..
The points were both broken springs and the best i could do was file the contacts, polish and solder on new springs.
I then ran on tester for the better part of the afternoon and it looks like the solder will hold.
Pretty unique distributor for the A engine. These engines seem to benifit from the mechanical advance more than most engines....
