Todd68390
Here's what I'm dealing with on the '32 I just bought. The brakes were converted to hydraulic long ago. The wheel cylinders were rebuilt, and the master cylinder was replaced recently. The brakes function well, but as you can see in the following pictures, pedal placement is not correct. It's quite a reach from the gas pedal up to the brake pedal. Your knee is almost up to the steering wheel. I found the foam pedal/column seal and metal retainer under the seat. When I removed the floorboards it became evident these are not '32 pedals. I'm lucky that the crossmember hasn't been cut. I want to retain the hydraulic brakes, but get the pedals and floorboards back to the correct configuration. I guess my first step is going to be installing correct '32 pedals and bracket.
