1937pickup
I had my flathead for my 37 pickup rebuilt a number of years ago. It is not the original, 8ba. I never could get the engine to idle the way I wanted or thought it should. By the way the engine has about 7500 miles. It always had a noisy valve on start up that would quit down when it warmed up. I had the carb re-built by a guy who used to be on this site. I put Marvel Mystery oil down the carb and in the gas, thinking it was a sticky valve. It would not idle to my satisfaction. I was going to remove the distributor, crab style, and send it to Bubba for new points etc. If that didn't work I was going to "cheat" and increase the idle speed.
Yesterday I changed the engine oil, transmission oil rear end oil and greased the truck. I started the truck and low and behold it ran perfectly. It was so quiet and smooth I could not believe it. The engine ran the way I thought it should. You could have set a glass of water on the engine and not seen a ripple. I sat and watched it run in amazement for 10 minutes.
I have no idea what happened or why it did this. I will be starting it tomorrow to see if it is the same, I hope so. Maybe it just needed some love.
