brianpharmd
My car came with an Rex-A-Co oil pressure gauge (0-10 reading). From the prior threads (2016-2014), I have read that oil pressure might be 3-5 when cold and 0 to nearly 0 when warm. However, my car is ******* the oil pressure gauge well beyond the 10 especially at higher speeds. At idle, pressure is around 2 but as I accelerate, the pressures increase to where they stop since the needle can't go up any further. Obviously I am building pressure in the engine, according to previous threads, is something that should have little to no pressure at all times. I can't find in any threads that I search with criteria "oil pressure" or "oil pressure gauge" any mention of overtly high readings. Most threads just talk about readings of 0 or people not installing/hooking up the gauge.
Any ideas on what I should be checking to eliminate the pressure? The car does not have the standard oil filler tube. It has a tube that allows blow by to be vented out of the engine and under the car. Should I prop open the lid to the oil filler tube and drive with it open to see if that adjusts the pressure reading? I have a rear main leak and I figure the pressure in the system is not helping it since that is the point of least resistance.
Thanks,
Brian
Thanks,
Brian
