Bob Bidonde
There is a rule of thumb to pour one quart of motor oil down the distributor hole in the cylinder head to assure that the crankshaft & camshaft bearings have an oil supply. This oil fills the reservoirs in the valve chamber. This is a very good practice.
However, the oil return pipe provides the oil that fills the dip tray, so the connecting rod bearings get oil. Considering the dip tray holds the better part of a quart of oil, I suggest that you put 2 quarts of motor oil or down the distributor hole so the oil overflows down the return pipe and fills the dip tray. It's likely there may already be oil in the dip tray, but to be sure add a 2nd quart of oil down the distributor hole.
