Many years ago when I had my own business we had several stationary engines that ran pumps, generators, and cement mixers, the majority of which were Kohler, or Wisconsin, single cylinder, twin and/or V4's.
We always used non-detergent 30w oil in the engines. We generally had the engines rebuilt in lieu of buying a replacement engine. Starting sometime in the early '70's the machine shop that rebuilt our stationary engines started asking us if we wanted babbit or insert bearings in the engine, the first time I was asked this question I wanted to know whats the difference? The reply, babbit bearing cost more, do to the added labor, the conversion to inserts is cheaper. Babit bearing require non-detergent oil whereas with inserts we could use detergent oil in the engine.
We generally purchased oil, 20/50 GTX Castrol in 50 gal drums because it would work in all of the vehicles, including the diesels.
I used GTX in my '36 Ford from the early '70's until about 10 years ago when I switched to Shell Rotella, Delo or Valvoline for diesels. usually 10-40..
