Can only assume that you are talking about the front and/or rear oil seal.Have any of you old Ford fellas used either Lucas or Blue Devil oil stop leak products with good results?? Or no results? Or, hopefully not, bad results?
Thanks
Years ago I had a minimal leak at the front seal and tried some stop leak.
It did not work because as stated the seals are not rubber.
Shortly after, I installed a PCV system and the leak virtually stopped.
I believe it stopped because of the negative pressure induced in the crankcase by the PCV system.
