34fordy
1936 Oil pressure gauge registers 5 lbs. I installed a mechanical gauge to check and it registers 35-40 lbs. Does this most likely indicate a faulty sender?
Is there a test to confirm this?
Does anyone have a picture of the inside after taking it apart from another gauge like mine in the picture on post #4, either 50# or 80#? Also, does anyone know the correct orientation vertically as after taking the cover off I do not know which way is supposed to be up. I did get the small hairlike wire reattached.
