Oil return pipe and Tappet cover.
RHD
Oil return pipe and valve cover parts anomaly in parts book.
There were two Model 'A' oil return pipes and two valve covers each with their respective pipes.
I have a parts book dated 1st July 1932 and it covers just about all mechanical parts except some of the really early parts.
The book shows an oil return pipe A-6645 and a tappet cover A-6520.
I presume they are a matching pair.
What happened to the other oil return pipe and it's cover? They are not in the book. These parts are very common and found in just about all home workshops all around the world.
Is this an error?
Like to hear your comments. I have attached pictures from the parts book.
What happened to the other oil return pipe and it's cover? They are not in the book. These parts are very common and found in just about all home workshops all around the world.k.
Ha ha ha
While we are on side covers
What is the small V cut out on the top centre of the gasket
Lawrie
I am not talking about the little knob part that is in the top in the pick,
The little vee cutout is in the top of the gasket as it sits one the engine, just under the manifold right in the area where the spring that holds the distributor drive gear in place
lawrie
lawrie
What vee cutout?
This is the gasket
Lawrie
That's the same gasket, the tabs are for the oil dams in the valve chamber.
It’s not the bit that seals the oil dams
It’s the little cut out vee in the top,they are a pain , as there is a relief in the block that allows the drive gear spring to seat in and unless you are very careful this vee exposes the groove where the said spring seats and will leak oil .
Lawrie
OK, now I see what your talking about. I'm a little slow some times.
Regarding the two oil return pipes and tappet covers.
I presume the parts numbered: Oil return pipe A-6645 and a tappet cover A-6520 are reasonably early, probably 28 and part 29.
Should the later parts be A-6645-B, and A-6520-B? Just as all the other parts are numbered in the parts book - 'B' 'C', etc.
