TomballMottershaw
So I pulled the engine out of my 30 Tudor. ( the engine is named: Puddler ) I pulled some of the engine apart, the pistons and crank shaft seem fine, all the head studs came out fine.
it has been sleeved back to stock pistons.
I found that the front valve gear cover tension spring setup was not doing any work.. it's jammed in the timing gear cover.
I looked at the back of the engine behind the flywheel housing where you can see the cam shaft.. it appears that oil is leaking here.
so my question are:
1.) on my rebuilt temporary engine, how does one seal this back end of the camshaft up ?
2.) could this be the cause of the dribbles/... line, of oil from the bell housing ?
3.) Should I just switch to a 4 cylinder OM616 Benz Diesel engine?
4.) any tips on installing this valve gear cover spring properly ?
re benz....just seeing if you read to the end
john.
so my question are:
john.
