Ronnieroadster
Ronnieroadster,Yes I do have the beehive oil filter. Pressure in on the bottom and out the side. Pressure line in from rear of block right?
The feed would be from the rear of the block out of the original oil sender location. Im not sure how the oil line would connect to the housing however if its like the original flathead set up the oil line coming out the bottom of the housing is the oil return to the oil pan only. Since its a beehive i would expect the oil return is only going to the oil pan just draining back into the pan not feeding the engine the oil under pressure. If the beehive is being used to actually feed the engine oil under pressure that may be the cause of the failure first if the oil lines are installed backwards and second the fact the beehive as far as i know is not designed to be the actual oil feed supply for the engine such as feeding oil under pressure to the bearings. Pictures of how the oil lines are connected would help determine how its actually being used.
Ronnieroadster
