They are easier to manufacture with no hobbing technology required and they are easier to heat treat but you never know how the ones for model A engines are made. If they cut corners, there is a lot better chance for problems.
And on the Model A, a lot less chance of catching it. As in no oil pump pressure indication.If they cut corners, there is a lot better chance for problems.
There you go!I just pulled the original pump gears from the degreaser bath, cleaned them up and inspected them. They are clearly machined, as the marks are very visible on both ends of each gear. There is also hardly any wear on the gear teeth or shaft. I think I’ll replace bushings and gaskets and reassemble the pump with the original gears.
