hardtimes Well-known member Jul 1, 2021 #1 Anyone know if this is A, B pump ? Thanks Attachments F6B39E26-C329-4FBC-9F19-F41C03BE303F.jpeg 89.4 KB · Views: 71 B833E682-AF52-42D6-9F19-BE31F6D39426.jpeg 74.9 KB · Views: 74 1CD26EF1-149B-49FB-A19D-BC3E9B4025F6.jpeg 90.8 KB · Views: 74 Last edited: Jul 1, 2021
tinkirk Senior Member Jul 1, 2021 #2 Kind of looks like the one that i put installed in brother in-laws 30 roadster Sent from my iPhone using Tapatalk
Bob Bidonde Well-known member Jul 2, 2021 #4 It is a Model "A" pump. The Model "A" & "B" pumps are fit, form and functionally interchangeable. There is a minute difference. The oil exit hole in the Model "B" pump is rectangular, but it is round in the Model "A's" pump.
J johnneilson Well-known member Jul 2, 2021 #5 Bob, you are correct, I believe it is an early "A" pump. more than likely the housing has only a 9/16" bore instead of the later 5/8" It can be modified to increase the output if necessary, just have to look at the application. John
D dave hummell Member Jul 2, 2021 #6 Don't forget the B oil pump shaft is cut down to I think .410 diameter for more flow.
