P Peter Pucak Member Aug 6, 2010 #1 On The A & B oil pumps, should there be a gasket between the bottom plate and the gears ??
Purdy Swoft Well-known member Aug 6, 2010 #2 peter pucak said: on the a & b oil pumps, should there be a gasket between the bottom plate and the gears ?? Click to expand... no!!!
Blessyouboys Senior Member Aug 6, 2010 #3 Is this the second thread you've started on the same topic?
B billwill Well-known member Aug 6, 2010 #4 Peter Pucak said: On The A & B oil pumps, should there be a gasket between the bottom plate and the gears ?? Click to expand... check the repair manuel that will showyou.Easy does lt.
