Oil Pump Flow
Bob, if I recall correctly sometime ago, you were batting around the idea of an oil filter rig external to the Model A. In other words, we take the dirty oil and run it through a filter (I presume many times). Is this latest question related to that earlier idea? And whatever became of it?
David, you have a fantastic memory. I was going to use an external oil filtering rig to clean my Model A's motor oil. However, I did not build the rig to do so. If you go to the MAFCLI website, https://www.modelalongisland.com, select "Resources"and you will see that I have been building a "Specifications" resource for my Model "A" club. That is why I want the oil pump data.
