I believe many A's have the bolt there and works fine. The correct solution for appearance is the plug. In my case I ordered the Snyders oil pump retainer not realizing I had a bolt in my block. Tried using the snyders part when I pulled the pan and the snyders part snapped in half. Heated the area up to get it out then used the bolt that was there to hold the pump in place when I put the pan back on. Doesn't leak, so I'm leaving the bolt in place (backed off of course) as I'm not going after judging points.
