If it is too low, here is the adjustment procedure: Remove and disassemble engine. Regrind crankshaft and reinstall with new, properly sized main and rod inserts. Replace camshaft bearings. Install new or rebuilt oil pump. Reassemble and reinstall engine.
If it is too high, remove and clean pressure relief valve in oil pump.
