Barry53
As suggested hooked in a pressure gauge, the readings were approx at idle in the region of 10-15lbs, with a few revs on the pressure was in the region of 30-40lbs. Hard to be to accurate as the gauge had a wide range. Next thing I will have to do is pull out the pressure sender to see what it is 50 or 80lb. As I understand most of the new pressure senders are the 80lbs. At least I can clock up few my miles safety figured crossed.
