Oil pressure sending unit.
Nope. There are many vendors selling repro'd original senders.
When you say "bogus readings", are they just off? Mine are too after 12v conversion, and they probably were when it was 6v. You can adjust the indicated pressure by removing the gauge unit from the dash, when you do you will see a hole in the back of the gauge and a sawtooth wheel inside. Very small adjustments make fairly large differences.
Donald 1950 hit it on the head. You can get a voltage resistor that will do all of them or individual voltage drops for each one.
Put a constant voltage regulator in the 12volt hot lead to your gauges, it will put 6 volts for your gauges. You can buy one at NAPA it is use on ford trucks and cars up thu 1975 or later. Dennis Carpenter has them for $20.00.
I guess I assumed you'd already addressed the voltage supply to the gauges. I had poor luck with the new CVR's, usual story, cheap chinese crap, mine was from NAPA. I bought an electronic regulator off eBay (http://www.ebay.com/itm/Ford-Instru...r_Truck_Parts_Accessories&hash=item3f41405095) and it works fine. But if you still have to address the heater fan motor and 6v windshield wipers, or 6v radio, nowadays I think one of these makes more sense. They can handle all the 6v accessories including the gauges: http://www.ebay.com/itm/Voltage-Reducer-Regulator-12-VOLTS-to-6-VOLTS-20-AMPS-/131351858723
As Ross said, the gauges are adjustable. Apply 1.5 volts, should read 1/2 scale 3 volts full scale. I also use a constant voltage regulator off an older Ford. Works fine on my '48 converted to 12V.
