44 flathead pickup
When I first start up oil pressure is at max, comes down as expected ad it warms up. If I drive around locally,stop start and maybe the odd 40-50mph cruise it is about 1/4-1/2 on the gauge. But if I go on a longer run at "higher" speed the needle will go right down to minimum, if I then slow right down for a while then speed up again the pressure will be restored back to a 1/4. Any thing to be concerned about? Would changing to 20/50 oil help?
Ian
Ian
