Oil pressure question
  • Thread starter Thread starter Guest
  • Start date Start date
G
Guest
Guest
The pressure at the tee on the non restricted side is the normal place to sense the oil pressure.
The restrictor passes such a small amount of oil to the oil filter in relation to the output of the oil pump it should not make much difference.
The 40 psi difference between the supply side of the restrictor and the filter side really don't matter as the oil in the filter just goes back to the oil pan any way.
If you are getting 60 psi at idle at normal operating temperature it sounds like a lot to me.
At normal a operating temperature at idle around 20 psi is about normal.
Newton
The oil filter circuit dumps into the pan through an open line, and is essentially a leak in the main circuit. There is high pressure before the restrictor because the restrictor cuts flow through the line to way less than is available. On the other side, the oil coming to the filter is restricted only by the filter element and the open steel line to the hole in the pan, which have more flow capacity than the restrictor, so pressure drops. If you measured on the OUT side of the filter, you'd probably get close to zero. Actually, the engine's total oil pressure in the main passages is also based on leakage rates--the oil is at high pressure because the pump is trying to stuff in more oil than can leak out around the edges of the bearings! The maximum pressure possible is governed by the oil pressure relief valve, which just adds a big leak when max pressure is passed.
Thanks, so it's not something to worry about. I didn't think so , but wanted to be sure.
