G
Guest
Guest
The pressure at the tee on the non restricted side is the normal place to sense the oil pressure.
The restrictor passes such a small amount of oil to the oil filter in relation to the output of the oil pump it should not make much difference.
The 40 psi difference between the supply side of the restrictor and the filter side really don't matter as the oil in the filter just goes back to the oil pan any way.
If you are getting 60 psi at idle at normal operating temperature it sounds like a lot to me.
At normal a operating temperature at idle around 20 psi is about normal.
Newton
Newton
